Beiträge: 446 Registriert: Fr 23. Jul 2021, 09:03
Has thanked: 23 times
Been thanked: 8 times
Beitrag
von Markus » Di 21. Mai 2024, 11:16
Warum zeigt diese Grafik die Forecast-Temperatur nicht mehr an?
type: custom:apexcharts-card
graph_span: 4d
span:
start: day
offset: '-1d'
now:
show: true
label: now
color_list:
- red
- yellow
- green
- blue
all_series_config:
unit: °C
apex_config:
chart:
height: 300px
yaxis:
tickAmount: 6
header:
show: true
show_states: true
colorize_states: true
series:
- entity: sensor.gw1000a_pro_outdoor_temperature
stroke_width: 2
curve: smooth
show:
extremas: true
extend_to: now
- entity: weather.openweathermap
curve: smooth
stroke_width: 1.5
type: line
unit: °C
extend_to: false
show:
in_header: false
legend_value: false
extremas: true
data_generator: |
return entity.attributes.forecast.map((entry) => {
return [new Date(entry.datetime).getTime(), entry.temperature];
- entity: sensor.day_night
curve: stepline
type: area
transform: 'return x === ''Day'' ? 0 : 30 ;'
color: grey
stroke_width: 0
opacity: 0.3
show:
in_header: false
legend_value: false
Die Entität weather.openweathermap hat folgende Attribute:
temperature: 20.6
apparent_temperature: 20.7
dew_point: 16
temperature_unit: °C
humidity: 75
cloud_coverage: 20
pressure: 1006
pressure_unit: hPa
wind_bearing: 90
wind_speed: 29.63
wind_speed_unit: km/h
visibility_unit: km
precipitation_unit: mm
attribution: Data provided by OpenWeatherMap
friendly_name: OpenWeatherMap
supported_features: 2
Beiträge: 469 Registriert: Do 22. Jul 2021, 16:57
Has thanked: 38 times
Been thanked: 26 times
Beitrag
von Friedi » Di 21. Mai 2024, 11:28
Sind das die einzigen Attribute? Wenn ja, liefert dein DWD kein Forecast, sondern nur einen Tag.
Bei mir sieht das so aus:
forecast:
- datetime: '2024-05-20T00:00:00Z'
condition: sunny
wind_bearing: 20.38
wind_gust_speed: 14.8
uv_index: 5
precipitation_probability: 1
temperature: 23
templow: 14
wind_speed: 7.4
precipitation: 0
- datetime: '2024-05-21T00:00:00Z'
condition: rainy
wind_bearing: 152.96
wind_gust_speed: 24.1
uv_index: 3
precipitation_probability: 79
temperature: 22
templow: 13
wind_speed: 11.1
precipitation: 13
- datetime: '2024-05-22T00:00:00Z'
condition: rainy
wind_bearing: 225.79
wind_gust_speed: 25.9
uv_index: 3
precipitation_probability: 76
temperature: 18
templow: 13
wind_speed: 13
precipitation: 9.3
- datetime: '2024-05-23T00:00:00Z'
condition: cloudy
wind_bearing: 231.67
wind_gust_speed: 20.4
uv_index: null
precipitation_probability: 26
temperature: 21
templow: 11
wind_speed: 9.3
precipitation: 0
- datetime: '2024-05-24T00:00:00Z'
condition: lightning-rainy
wind_bearing: 157.62
wind_gust_speed: 22.2
uv_index: null
precipitation_probability: 43
temperature: 21
templow: 10
wind_speed: 11.1
precipitation: 1.3
- datetime: '2024-05-25T00:00:00Z'
condition: cloudy
wind_bearing: 336.54
uv_index: null
precipitation_probability: 34
temperature: 23
templow: 11
wind_speed: 9.3
precipitation: 0
- datetime: '2024-05-26T00:00:00Z'
condition: cloudy
wind_bearing: 237.46
uv_index: null
precipitation_probability: 16
temperature: 23
templow: 11
wind_speed: 9.3
precipitation: 0
- datetime: '2024-05-27T00:00:00Z'
condition: sunny
wind_bearing: 259.38
uv_index: null
precipitation_probability: 29
temperature: 24
templow: 11
wind_speed: 9.3
precipitation: 0
- datetime: '2024-05-28T00:00:00Z'
condition: partlycloudy
wind_bearing: 157.33
uv_index: null
precipitation_probability: 19
temperature: 24
templow: 12
wind_speed: 11.1
precipitation: 0
friendly_name: forecast_dwd
Zeig mal den Code deines Sensors.
Beitrag
von Markus » Di 21. Mai 2024, 11:39
Wenn ich auf das i klicke kommt mehr. Das ist kein Sensor sondern die Openweather-Integration.
Screenshot 2024-05-21 113709.png (45.87 KiB) 917 mal betrachtet
Beitrag
von Friedi » Di 21. Mai 2024, 12:59
Das reicht nicht. Da gab es ja eine (lang angekündigte) Umstellung. Da musst du dir mal nen Sensor bauen.
- trigger:
at: '00:00:00'
at: '12:00:00'
- service: weather.get_forecasts
type: daily
entity_id: weather.DEINE_STATION
response_variable: daily
- name: forecast_dwd
unique_id: forecast_dwd
state: "{{ now().isoformat() }}"
attributes:
forecast: "{{ daily['weather.DEINE_STATION'].forecast }}"
Und den baust du dann da ein.
Beitrag
von Markus » Mi 22. Mai 2024, 21:53
hmm, wieso bekomm ich keine Werte rein, hätte bewusst den trigger auf minutes mal gesetzt:
- trigger:
- platform: time_pattern
minutes: /1
type: daily
entity_id: weather.openweathermap
response_variable: vorhersage
- name: Temperatur-Vorhersage der nächsten Stunde
unique_id: temperature_forecast_next_hour
icon: mdi:hours-24
attributes:
forecast: "{{ vorhersage['weather.openweathermap'].forecast }}"
Beitrag
von Friedi » Do 23. Mai 2024, 06:14
Markus hat geschrieben: ↑ Mi 22. Mai 2024, 21:53
Also mehr als 2 mal am Tag wird nichts bringen, da der Wetterdienst normalerweis enicht so oft aktualisiert.
Woher hast du diesen seltsamen Code?
attributes:
Ich kann mir nicht vorstellen, dass Open Weather Map etwas wie Vorhersage zur Verfügung stellt. Das daily in meinem Code gibt es ...
Beitrag
von Markus » Do 23. Mai 2024, 06:28
Friedi hat geschrieben: ↑ Do 23. Mai 2024, 06:14
Variante OldSchool, oder hab ich das falsch verstanden?
https://www.simon42.com/home-assistant- ... rhersagen/
Dh. deine Variante würde 2x täglich Werte abholen und bis dahin bleibt es auf unknown?
- trigger:
at: '00:00:00'
at: '12:00:00'
type: daily
- name: forecast_weather
unique_id: c4a7bbf2-1814-46ab-9e1f-e6f6ad42410b
icon: mdi:hours-24
attributes:
forecast: "{{ daily['weather.openweathermap'].forecast }}"
Beitrag
von Friedi » Do 23. Mai 2024, 06:40
Die Werte werden 2x täglich abgeholt und der Wert bleibt halt so lange erhalten, bis er durch das nächste Mal Abholen geändert wird.
Simon42 lesen ist mir jetzt zu viel
Mir fällt gerade auf, dass du hier gar keine Station eingetragen hast:
type: daily
Welches Wetter soll denn da gezogen werden?
Beitrag
von Markus » Do 23. Mai 2024, 06:50
Verständnisfrage, welche Station sollte das sein? Dachte weather.openweathermap wäre hier der erforderlich Eintrag?
Beitrag
von Friedi » Do 23. Mai 2024, 08:04
Naja, eine Station in deinem näheren Umfeld ...
Konkret sieht das bei mir so aus:
- trigger:
at: '00:00:00'
at: '12:00:00'
type: daily
entity_id: weather.bamberg_10675
attributes:
forecast: "{{ daily['weather.bamberg_10675'].forecast }}"
Beitrag
von Markus » Do 23. Mai 2024, 11:05
Irgendwie stehe ich auf der Leitung, wie komme ich zu dieser Station bzw. was ist das überhaupt für eine Station (eigene, openweather...?)
Beitrag
von Friedi » Do 23. Mai 2024, 13:12
Ach, sorry!!!
Jetzt checke ich erst, das Thema mit OpenWeather Map. Ich beziehe meine Daten vom DWD, da ich hier stationsgenau abfragen kann.
Auch Simon42 verwendet hier kein OpenWeatherMap sondern die Weather-Integration. Bei OWM scheint es auch je nach Bedarf verschiedene APIs zu geben: https://openweathermap.org/api .
