Hatte vorher keinen AppDaemon3 laufen. Port 5050 ist in der Configuration eingestellt.
Log
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] 00-banner.sh: executing...
Add-on: AppDaemon 4
Python Apps and Dashboard using AppDaemon 4.x for Home Assistant
Add-on version: 0.8.1
System: Home Assistant OS 7.1 (aarch64 / raspberrypi4-64)
Home Assistant Core: 2021.12.10
Home Assistant Supervisor: 2021.12.2
[cont-init.d] 00-banner.sh: exited 0.
[cont-init.d] 01-log-level.sh: executing...
[cont-init.d] 01-log-level.sh: exited 0.
[cont-init.d] appdaemon.sh: executing...
[cont-init.d] appdaemon.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[13:36:30] INFO: Starting AppDaemon...
File "/usr/bin/appdaemon", line 8, in <module>
sys.exit(main())
File "/usr/lib/python3.9/site-packages/appdaemon/__main__.py", line 443, in main
admain.main()
File "/usr/lib/python3.9/site-packages/appdaemon/__main__.py", line 387, in main
self.logging = logging.Logging(logs, args.debug)
File "/usr/lib/python3.9/site-packages/appdaemon/logging.py", line 274, in __init__
logger = logging.getLogger(args["name"])
KeyError: 'name'
[13:36:34] INFO: Starting AppDaemon...
sys.exit(main())
admain.main()
KeyError: 'name'
