PV Excess Control > Fehlersuche?
Has thanked: 21 times
Hat zufällig jemand den Blueprint von PV Excess Control am laufen?
Aufgrund der vielen Eingangsparameter komme ich nicht so recht dahinter an was es scheitert?
Step Details zeigt:
Executed: 13. August 2023 um 08:55:00
Result:
params:
  domain: pyscript
  service: pv_excess_control
  service_data:
    automation_id: automation.steuerung_pv_excess_optimizer_lmx
    appliance_priority: 1
    export_power: sensor.varta_battery_grid_power
    pv_power: sensor.rounded_solardedgeproduktion2
    load_power: sensor.loadpower
    home_battery_level: sensor.mb_varta_soc
    min_home_battery_level: 35
    dynamic_current_appliance: false
    appliance_phases: 1
    min_current: 6
    max_current: 16
    appliance_switch: light.h619a_435f_office
    appliance_switch_interval: 5
    appliance_current_set_entity: null
    actual_power: null
    defined_current: 6
    appliance_on_only: false
    grid_voltage: 230
    import_export_power: sensor.combined
    home_battery_capacity: 17.5
    solar_production_forecast: sensor.energy_production_today_2
    appliance_once_only: false
  target: {}
running_script: false
Step Config
service: pyscript.pv_excess_control
  appliance_phases: 1
  min_current: 6
  max_current: 16
  actual_power: null
  defined_current: 6
  grid_voltage: 230
Trace Timeline gibt u.a aus:
 (sensor.checkpvexcess) turned False
