Frigate startet nicht
Verfasst: Do 8. Feb 2024, 21:24
Wie sind diese Fehler zu verstehen? Hatte vor kurzem nur den Retain-Wert in der frigate.yaml geändert...
024-02-07 06:27:37.573309466 [INFO] Starting go2rtc healthcheck service...
2024-02-07 06:27:41.234813826 2024/02/07 07:27:41 [error] 148#148: *1 connect() failed (111: Connection refused) while connecting to upstream, client: 172.30.32.1, server: , request: "GET /api/stats HTTP/1.1", upstream: "http://127.0.0.1:5001stats", host: "xxxxx-frigate:5000"
2024-02-07 06:27:42.380612798 2024/02/07 07:27:42 [error] 149#149: *3 connect() failed (111: Connection refused) while connecting to upstream, client: 127.0.0.1, server: , request: "GET /api/version HTTP/1.1", upstream: "http://127.0.0.1:5001version", host: "127.0.0.1:5000"
