GPS Standortaktualisierungs-Intervall
Verfasst: Mi 15. Mai 2024, 07:24
von PX80
guten morgen,
kann man die Intervalle der Standortabfrage verkürzen? Manchmal bekomme ich nur aller 20-60min ein update.
Re: GPS Standortaktualisierungs-Intervall
Verfasst: Mi 15. Mai 2024, 07:31
von PX80
gerade gefunden und werde dies mal ausprobieren
https://companion.home-assistant.io/doc ... %20updates.
Android Location Sensors
Android Android users can find custom sensor settings for location tracking under Settings > Companion App > Manage Sensors > Location Sensors. These sensors all require that the app has proper location permissions and location is enabled on the device, if either of these requirements are not met then the sensors will become disabled.
The first sensor is Background Location this sensor is responsible for registering frequent background updates using Google's Fused Location API. Updates come in typically between 1-3 minutes but can be as often as every 30 seconds when you are using navigation like Google Maps.
Background Location also offers high accuracy mode so you can get even faster updates. The state of this mode can be determined by the next location sensor High Accuracy Mode which simply reports if the mode is enabled. This sensor is not directly related to location updates that you get from Google.
The third location sensor is Location Zone, when enabled this sensor will get a list of all configured zones and will use Google's location service to create geofences containing zone data. This will allow for faster entry and exit detection while remaining battery friendly.
The last location sensor is Single Accurate Location this sensor only gets used if the reported accuracy did not meet the criteria as set in the sensor settings. This sensor is also used when the notification command or an intent was received by the app.
