AppDaemon: WebGUI startet nicht
Verfasst: Mo 17. Jan 2022, 18:41
von Markus
Wäre gerade beim einrichten von AppDaemon4, warum auch immer startet die WebGUI nicht. Hat jemand einen Tipp was falsch ist?
Configuration
init_commands: []
python_packages: []
system_packages: []
log_level: info
appdaemon.yaml
secrets: /config/secrets.yaml
appdaemon:
latitude: !secret latitude
longitude: !secret longitude
elevation: !secret elevation
time_zone: CET
plugins:
HASS:
type: hass
ha_url: http://192.168.200.179:8123
token: !secret appdaemon_token
app_init_delay: 20
http:
url: http://xxx.x.x.x:5050
admin:
api:
hadashboard:
logs:
error_log:
filename: /config/appdaemon/logs/error.log
main_log:
filename: /config/appdaemon/logs/appdaemon.log
acces_log:
filename: /config/appdaemon/logs/access.log
diag_log:
filename: /config/appdaemon/logs/diag.log
log_generations: 5
log_size: 1024
format: "{asctime} {levelname:<8} {appname:<10}: {message}"
retic_log:
filename: /config/appdaemon/logs/retic.log
flash:
filename: /config/appdaemon/logs/flash.log
Re: AppDaemon: WebGUI startet nicht
Verfasst: Di 18. Jan 2022, 13:47
von azrael783
Läuft bei mir in einer Testumgebung ohne irgendetwas an den Einstellungen geändert zu haben. Hattest du vorher die Version 3 von AppDaemon laufen? Wenn ja solltest du mal in die Doku gucken:
Upgrading from AppDaemon 3.x
If you have previously ran AppDaemon 3.x (e.g., via an add-on), these steps will help you getting upgraded to AppDaemon 4.x.
After installing this add-on, stop the current running AppDaemon 3.x add-on.
Open your /config/appdaemon/appdaemon.yaml file in an editor.
Remove the log.
Removethreads, api_port, app_dir, ha_url and token.
Add the following to the appdaemon section: latitude, longitude, elevation and time_zone.
Add a http section with url: http://127.0.0.1:5050 in it.
At the end of the file add admin: and api:.
Remove everthing under hadashboard:, leaving just that.
Wenn nicht, hast du in der Konfiguration einen Port angegeben? Standardmäßig wird da wohl der Port 5050 verwendet.
Verfasst: Di 18. Jan 2022, 14:06
von Markus
Hatte vorher keinen AppDaemon3 laufen. Port 5050 ist in der Configuration eingestellt.
Log
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] 00-banner.sh: executing...
Add-on: AppDaemon 4
Python Apps and Dashboard using AppDaemon 4.x for Home Assistant
Add-on version: 0.8.1
You are running the latest version of this add-on.
System: Home Assistant OS 7.1 (aarch64 / raspberrypi4-64)
Home Assistant Core: 2021.12.10
Home Assistant Supervisor: 2021.12.2
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
[cont-init.d] 00-banner.sh: exited 0.
[cont-init.d] 01-log-level.sh: executing...
[cont-init.d] 01-log-level.sh: exited 0.
[cont-init.d] appdaemon.sh: executing...
[cont-init.d] appdaemon.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[13:36:30] INFO: Starting AppDaemon...
File "/usr/bin/appdaemon", line 8, in <module>
sys.exit(main())
File "/usr/lib/python3.9/site-packages/appdaemon/__main__.py", line 443, in main
admain.main()
File "/usr/lib/python3.9/site-packages/appdaemon/__main__.py", line 387, in main
self.logging = logging.Logging(logs, args.debug)
File "/usr/lib/python3.9/site-packages/appdaemon/logging.py", line 274, in __init__
logger = logging.getLogger(args["name"])
KeyError: 'name'
[13:36:34] INFO: Starting AppDaemon...
sys.exit(main())
admain.main()
KeyError: 'name'
Verfasst: Di 18. Jan 2022, 16:26
von azrael783
Merkwürdig, ich gucke heute Abend nochmal in die Configs rein, habe da momentan keinen Zugriff drauf
Verfasst: Di 18. Jan 2022, 21:22
von azrael783
Also, hier der Inhalt der 'appdaemon.yaml':
appdaemon:
latitude: 52.379189
longitude: 4.899431
elevation: 2
time_zone: Europe/Amsterdam
plugins:
HASS:
type: hass
http:
admin:
api:
hadashboard:
und der Inhalt der 'configuration.yaml':
default_config:
# Text to speech
tts:
- platform: google_translate
group: !include groups.yaml
script: !include scripts.yaml
scene: !include scenes.yaml
Wie gesagt, ist ein Dev System an dem ich noch nicht wirklich viel gemacht habe. Hast du mal die ganzen Log Einträge versucht auszukommentieren?
Verfasst: Mi 19. Jan 2022, 07:58
von Markus
Danke, es lag wohl an den logs.
Verfasst: Mi 19. Jan 2022, 08:11
von azrael783
Gerne, freut mich wenn ich helfen konnte
